Windshield freezeing
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
Hello, does anybody else have this type of issue on there ford ranger? Yes I know there is some ice in the wiper but it’s acting like maybe the wiper almost isn’t even touching the glass in the spot, is it warped I don’t know it works in rain but when it’s cold it doesn’t and sometimes it wipes clean and sometimes it don’t. There ford motor company wipers and there only 3 months old
Can you go out and get it off with a scraper? If it's stuck pretty good to the windshield the wipers won't get it off until it melts from the defroster. And of course the defroster doesn't work till the engine warms up.
corrosion in the base of the arm prevents it from putting pressure on the glass. the spring can't pull it down with enough force.
pull the arm all the way up a few times, light oil or WD40 at the pivot points.
Hmm okay thank you
Well the rest of the windshield is clear and so like it almost acts like the wiper isn’t even touching the class in that path, if I go out and get it with my hand it comes off
there is a small tab that slides to keep the wiper raised up about 2 inches. that takes pressure off the splined stub for easier removal of the entire arm.
the tab won't move unless pressure is released.
raise the arm a couple inches and see if the tab slides back 'n forth.
if it's corrosion holding it up try putting some pressure on the arm to push it past the point it normally stops at. that's into the glass, not sweeping across the glass.
I don’t know why but I had a very hard time understanding what your talking about here
internet descriptions can be a challenge.
" if I go out and get it with my hand it comes off"
I interpreted that as the arm coming off the stud/drive hub,, so that only happens if the arm is raised & locked up with the sliding tab.
or does that mean it's easy to lift the wiper off the glass? that would be lack of spring pressure and/or corroded pivot pin.
even with properly working springs and stuff there is very little pressure holding the blade against the glass so the arm parts must be flexible for full contact & cleaning.
Okay im still a little confused but I will go out an check this out after work
Ok so what your saying is, either the wiper arm itself is slipped off a little effecting the pressure the wiper arm has on the wiper or the spring is corroded
Event Coverage
TRS Merch
