Won't start after oil change
Rippin' Ranger
Forum Member
Mobile, AL
I have a strange issue I am hoping someone else has maybe run into or can help with. I did an oil change on my 2001 3.0 Ranger yesterday. I was having a heck of a time getting the filter off and so I removed the starter motor to give me a little more room. Unfortunately I forgot to remove the battery cable and sparks flew, shorted it out. I took it to Autozone and they tested it, said it was dead, I got a replacement. Installed that, it still won't start. The dash lights come on, I can hear the fuel pump running, but when I turn the key I get a click and that's it - does not turn over. I checked the ignition fuse in the cab, the one in the engine bay fuse box, swapped the relay with the blower motor all to no avail. I tested the new starter motor by connecting it directly to the battery, it works. I re-did the wiring connection for the solenoid wire as it was a little rickety. Still no good. I also considered perhaps the anti-theft had been triggered but the anti-theft light does not indicate that is the case. I tried both the disconnecting the battery for 15 min trick and the leave key in on position for 10 min trick. No good there either. Any body else have any ideas?
Sounds like you have a bad connection on either the battery +ve or -ve. Check connections at battery and solenoid/relay and starter. Check battery ground at motor if it doesnt go to starter.
@Rippin' Ranger
Are you saying that that battery was checked dead or the starter?
I agree with alwaysFlOoReD. Chwck your battery connections and starter connections. Make sure you have battery voltage on the big positive terminal.at the starter.
I'm getting 12v at the main power cable from the positive battery terminal, but zero from the smaller solenoid switch. However, this does not make sense to me as I can see the starter gear engage through the view port on the transmission, it just doesn't spin. I'm going to try cleaning up the battery cables to make sure the connection is good, but they don't really have a lot of corrosion on them.
Gaz: the starter motor was checked. And I checked the new starter motor as well by connecting it directly to the battery and connecting the terminals with a screwdriver - it engages and spins with that test using the batter that is already in the truck.
Everything worked fine before the oil change when I shorted the first starter motor. I wonder if I fried the ignition switch? But then I would think the starter gear would not engage when the key is turned and it definitely does - just does not spin.
You should only get battery voltage from the starter relay (what you called the "smaller solenoid switch") when you turn the key to the start position.
If turning the key makes the bendix gear shoot out and engage the flywheel, then the starter relay and the solenoid (which is built into the starter and actually pushes the bendix gear forward) are working. If the starter doesn't rotate, then the motor is bad or the battery is too weak to send enough voltage to spin it while engaged with the flywheel.
The start relay wire (the smaller one) does not get voltage with key in the "start" position when I check it with multimeter with starter out of the vehicle. However, when everything is back together and start attempted I can see the starter gear engage and hear the click but it does not spin. This is what does not make sense to me. If I'm not getting any power to the small wire to the solenoid, how is it engaging when I reassemble it? And if I'm getting 12v on the larger power wire, then why is the gear not spinning?
Almost sounds like you have those connections reversed.
The solenoid built into the starter does 2 functions.
1. It throws the bendux gear forward to engage the flywheel.
2. It closes a set of contacts to send power from the big battery cable to the motor windings to make the motor spin.
Check every fuse in the truck.
This still makes no sense to me, but I scrubbed the battery cables and terminals really well and that seemed to do the trick. I guess it wasn't pulling enough juice to spin the gear. It still makes no sense to me that this just decided to happen because I changed the oil and shorted the old starter motor. But I appreciate all the help and suggestions. Happy New Year!
Unfortunately, that would be a waste of time. The only part of the starting circuit that goes through a fuse is the ignition switch circuit to the starter relay coil terminal.
This is standard procedure for me when big current has been sent through any circuit in a vehicle. Strange things happen, and fuses blow in circuits you wouldn't think have anything to do with the starter circuit.
So I will
And usually find more than one blown fuse. I'll use a test light and touch both sides of the fuse (both sides will light if the fuse is good). In this case, there is a 50 amp fuse in the battery junction box and a 7.5 amp fuse in the under dash box, both of which will interrupt power to the start terminal of the starter.
