'90 Speedometer now reads way off than before
RangerReviver1990
Forum Member
Havelock
NC - USA
Other
2018 Ford Escape
Vehicle
Drive
2’ Leveling Kit
So, for context, when I bought my '90 back in '20 or '21, it came with this quote large 31 inch all terrains and they've been pretty good, but they did make my speedometer off by 2-3 mph around 45-55 and the 5mph, anything over 60, I've definitely gotten used to it. But recently, when I flushed my radiator and was driving around the Outer Banks for a couple hours to get all the cruise out of my cooling system, I didn't think anything was wrong with the truck, but the next day or maybe the day after that my speedometer was even more inaccurate than it had been, and I'm guessing around that time the speed sensor in my transmission went bad or started to fail because it would shift between 3rd and overdrive constantly. But yesterday was especially terrible. Idk if I stretched the cable out or something but I was driving down the highway was looking down at my Speedometer and it was reading 45mph but I was going closer to 65-70, because I know my truck usually runs at 2k rpm at that speed. Anyway, replaced the speed sensor (which was the biggest pain in my ass ever), the 19-tooth gear that was in it was still pretty good, I just stuck it on the new one and stuck the sensor into the transmission, but now there's like a, almost clocking or flapping noise coming from the dash, and I know it's probably because I accidentally pulled on the cable and it's probably not seated correctly, but like, at the same time, I'm still bummed that I wanted to fix this speed sensor, but it ended up making my speedometer even more horrendously inaccurate and now I think I messed up my speedometer cable. What would you guys do, In my situation?
For one you need one less tooth on your speedo gear to get your speedo reading closer.
For two either you need to lube the cable or there's something wrong with your speedo itself maybe corrosion in there...
On a 90 the sensor has no effect on speedometer operation.
Cable lube is a commonly overlooked maintenance item. I end up giving mine a little spray every 9 months or so. It'll start binding in cold weather and make the speedometer jump between 30 and 60 at like 5mph... Kinda funny actually.
Sounds like you may have a cable with a broken fiber scraping the sheath.
Well mine for the longest one would start wobbling at 55 or so if I wasn't giving it much, just enough to get up to cruising speed. But now that you mentioned the fiber scraping the sheath. When it hits around 20-25 miles an hour. You can really start to hear the tapping, and I can see that Everytime the tapping is made, the needle jumps a little bit. I was just gonna take the cluster out after work and see if it's not in all the way, but I might either put some oil on it or just go find a replacement. I maybe tugged on it a little too hard trying to get the new speed sensor on, because it really did not wanna go on, I had to wiggle it back and forth for like 15 minutes to get it to a point I could slide the pin in
The cable should be anchored to the firewall right by the gas pedal. Unlikely you damaged anything farther up by pulling unless you pulled the cable through the sheath.
Get that firewall anchor off and it'll be much easier to remove the cable from the speedometer. I don't think I ever bothered putting mine back.
Update, I found out that the bracket that holds the speed speed sensor and was on backwards and it kind of made the sensor stick out a little bit so I was thinking "oh maybe that's the problem". I spent about maybe 30 minutes trying to get it off and I flipped it around it and put it back in correctly. And now my speedometer isn't picking up anything from the gear until I hit about 50 or 55, But then it reads on the speedometers me going 15 mph and now I've completely lost overdrive gear instead of just having fourth gear and no overdrive. I'm now running like 2500 RPM at 50 mph and now I really don't know what to do. like, I have a new gear, It's an 18 tooth instead of the 19 tooth that's on it my but I don't know what where to go after this or what to look for after this because now it's almost like I've ruined it more by trying to replace the speed sensor
I'm not much help with an automatic transmission. But for the speedometer to act like that either a gear is mashed down by the speed sensor, the cable is (almost) broken, or something happened in the gauge itself. Only way to know for sure is to take it apart.
I'd start with the speed sensor because if it's not turning correctly I could see that affecting the shifts. IDK how much computer control there was for that in 90.
Yeah, now that I took it off for a second time, the original gear was shredded, so I swapped it to the 18-tooth gear and it seems to work good, got my overdrive back, it's off at speeds above 35 mph, but everything works now, can complain though, We chilling
Congrats. Wonder what happened?
I don't even know. But now I'm back to square one. Only had the new sensor on there for about a week or 2 at this point and now I've lost overdrive and it shifts in and out of overdrive when I'm trying to accelerate at highway speeds and then when it finally calms down when I'm cruising, it just will not shift into overdrive, even when I let off the gas a little and wait for it to engage, it engages for a seconds and then disengages. I'm not sure what to look for now. Unless the sensor i got failed prematurely or something. And I can't really remember anything of when the original one went bad except after I did a coolant flush and drove for about 4 hours, I noticed the speedometer was off by a ton and then it shift in and out of every gear. I don't wanna really tear into this because this is my only vehicle atm
Is it possible the gear in the transmission is damaged and shredded the new gear on the cable/sensor?
Event Coverage
TRS Merch
