Wanted Manual transfer case shifter for 1987
Suwanee Broncos
Long haired country boy
💻 TRS Socials
KUTTAWA
KY - USA
Other
1954 Chevy 3100/ K10 frame swapped
Vehicle
Ford Bronco II
Drive
33x12.50
Do justly, love mercy, walk humbly with your God. - Micah 6:8
I'm needing everything shifter related for the transfer case after doing a manual case swap. Even better if you have the boot/ floor bezel to go with a manual transmission.
You'll need to tell us what transmission & transfer case you're using. There are several shifter variants in the 80's and a couple different shift arm lengths on the transfer case.
FM145 and BW1350
Dang I thought I had one but I don't. I'll keep my eyes open.
That should be one or the easier to find combos, but I'd be considering any Ranger manual shifter and mod to fit. They're hard to come by.
Good luck.
Good luck.
For sure. Otherwise I'm stuck building from scratch anyway.
I think I have what you need, let me take a look. Let me check if the t case that came with my used fm145 is a 1350, I just swapped transmissions still have the transfer case and shifters/boot
That would be awesome. We just started it today for the first time. Hopefully we have a driveshaft to put in Monday and he'll get to drive it for the first time after working on it since April.
Event Coverage
TRS Merch
