1992 Ranger 4.0L Vehicle Speed Sensor Question
Rum Runner
Forum Member
Pelham
AL - USA
Vehicle
Drive
I can use any help I can get on this subject. You guys are very clever. The only question I know to ask is:: How much impact does the speed sensor have on transmission shifts for a 1992 A4LD transmission? I am aware of the speedometer on this truck being kinda wonky in the past years, more like on and off with the accuracy. It kinda wobbled some too. Are these things hard to replace? I read they can have 16 or 18 teeth in the gears? I'm just trying to keep this Ranger out of a junkyard somewhere. Get it back running properly. Thanks.
It would impact the 3-4 shift and the torque convertor clutch engagement. Fairly big impact. The speed sensor should be on the lefthand side of the transmission. If it's incorporated in the speed cable system, you should be able to take it apart and pull the assembly out and inspect the plastic gear for wear underneath the truck.
The 3-4 shift and the torque convertor clutch engagement is where the problems are happening. Your answer was the answer I was looking for. You may have saved an old Ranger from a scrap yard. Available parts show Delphi, Dorman sensors in the $20 range. Motorcraft OEM shows $208. Is there a quality preference, one part over another? Motorcraft is made south of the border, Dorman is made in the orient. Thank you for your reply.
I would pull it apart first and eye it over. I have never worked on your actual model, but some of the speed sensors are just mounted inline with the speedometer cable. If that is true, the old speedometer cable drive plastic gears have been known to wear, so you might just need the gear. Or it may be ok. You can also pull it out and twirl it with you fingers and see how it feels. If it's smooth or if it's sticky. If it's sticky, you can possibly unplug the speedo cable from it and then see if the cable is the problem or the sensor is the problem. Look the wires and the wiring plugs over good too.
Thanks. I noticed a few people that have made speed sensor purchases for older vehicles were given electronic speed sensors. The mechanical sensors for older vehicles have a metal clip in the open end of the sensor and electronic sensors have a white plastic piece in the open end.
Sorry for the delay, I got sidelined in a big way. I got to the part of pulling out the sensor and examining the gear. When trying to disconnect the sensor from the speedo cable nothing came loose. There is a clip that doesn't come out of the sensor with the speedo cable installed. Is that a retaining clip that allows the speedo cable to snap in or snap out? I didn't want to force anything and damage the cable. Thanks. David
Get a hook tool or something, that clip should pull out sideways. It just locks it in place. When you put it back together, you will have to slide the clip back in place.
Ah beans… I was going to get under the Choptop and take a look at mine and forgot…
Ha, I saw a video of a fellow break a speed sensor in two pieces trying to get that clip out. I pulled on this one until it bent the clip downward. I will give it another look and maybe buy an extra clip. Thanks for replying.
Weather turned to crap today, I may venture out for a couple errands and I may or may not make it down to my shop, but I for sure don’t intend on crawling under a vehicle today with the wind howling and rain/snow/sleet coming down. Wish my dang garage was up. Maybe tomorrow I can get a look at things if I can remember to or get a reminder, lol
If memory serves (which is less and less . . . ), you don't have to completely remove the clip. Pry the clip out while pulling and wigglin' the cable; it should slip out when the wide part of the clip opening lines up with the cable end's shoulders.
I think that the other side of the cable end is beveled, so that it can just be pushed in to reinstall, with the clip seated.
Event Coverage
TRS Merch
