Mileage
I’m working with the oldest guy in the shop but we can’t find a NGS diagnostic to see how the motor is actually working, he’s trying to find the books for the codes but we can’t find it, and the ford workshop manual doesent load up cuz the program they used is too old
To enlighten or confuse, I plugged the code 177 into Copilot AI. Here's what it said:
Quick Answer:
Code 177 on your 1994 Ford Ranger 4.0L (federal emissions) means the PCM sees the left/front oxygen sensor stuck rich—it’s not switching lean/rich as expected. This can be caused by a bad O2 sensor, wiring issues, or an actual rich-running condition (fuel system problem).
🔎 What Code 177 Means
  • Definition: “Oxygen sensor not switching – system rich, Left or Front HO2S.”
  • The PCM expects the heated oxygen sensor (HO2S) to cycle between lean and rich once the engine warms up.
  • If the sensor stays rich (high voltage) for too long, the PCM logs Code 177.
⚙️ Common Causes
  • Faulty O2 sensor (HO2S): The sensor itself may be worn out or contaminated.
  • Wiring/connectors: Damaged wiring, poor grounds, or corroded connectors can prevent proper sensor signals.
  • Fuel system running rich:
    • Leaking fuel injectors
    • High fuel pressure (bad regulator)
    • Dirty or faulty MAF sensor (common on these Rangers)
    • Vacuum leaks (less common here, but can skew mixture)
  • Exhaust leaks before the sensor: Can confuse readings.
🛠️ Diagnostic Steps
  1. Warm up the engine – Code usually sets after 5–7 minutes when the sensor should be active.
  2. Check sensor voltage with a multimeter or scan tool:
    • It should cycle between ~0.1V (lean) and ~0.9V (rich).
    • If it stays high (>0.7V), the PCM sees “always rich.”
  3. Inspect wiring/connectors – Look for frayed wires or corrosion.
  4. Check fuel pressure – A stuck regulator can cause rich running.
  5. Clean MAF sensor – A dirty MAF often causes rich mixture on these trucks.
  6. Replace O2 sensor if needed – If wiring and fuel system check out, the sensor itself is likely bad.
⚠️ Risks of Ignoring
  • Poor fuel economy
  • Fouled spark plugs
  • Catalytic converter damage from prolonged rich mixture
✅ Recommended Next Step
Since your Ranger is a 1994 with federal emissions, the front/left O2 sensor (driver’s side) is the one to check first. If you don’t have a scan tool, replacing the sensor is often the most straightforward fix, but it’s smart to check fuel pressure and clean the MAF before throwing parts at it.
In short: Code 177 means your PCM sees the left/front O2 sensor stuck rich. Start by checking sensor voltage, wiring, and fuel system. Cleaning the MAF and verifying fuel pressure are easy first steps; if those check out, replace the O2 sensor.
Sources:
Would you like me to walk you through a step-by-step test procedure with a multimeter so you can confirm whether the sensor itself is bad before replacing it?
The EEC IV diag manual wasn't online, it was a book about 4-5 inches thick for each model year.
177(M) Oxygen sensor not switching – system was rich Left or Front HO2S – Fuel control
Note that it says left. That's gonna be the driver's side.
Any time I have an O2 sensor code, I pull plugs first to make a slightly more educated guess as to how it's actually running. That color can tell you a whole lot.
Vacuum leaks, or leaking fuel pressure regulator can affect one side more than the other.
Quick Answer:
⚙️ Common Causes
🛠️ Diagnostic Steps
  • Poor fuel economy
Sources:
Thank you I ended up ordering 2 sensors for it as well I got new plugs for the truck
My Choptop was getting 12 mpg with a 4.0 being run on a 91 Ranger system. I finally bought a remanned computer for it (it’s a manual and I had been running it on an auto computer because I was having trouble finding the correct computer). Popped the cover off the old computer and found all three capacitors popped and took out a couple resistors. Put a new oxygen sensor in because it wasn’t that expensive. Runs better than it ever has now and my fuel economy has jumped significantly. I’m not sure what it is right now but I’m betting at least 15-18 mpg. Not bad for running on 35” tires
Can you put a manual computer with an auto harness?
I wouldn’t see why not. My harness in the Choptop is, oddly enough, a manual transmission harness, even though I was running it with an auto computer. Not ideal, but it works.
The thing with going the other way, manual computer and auto harness, is that it would be fine if you have a manual transmission. Someone really enterprising could actually just un-pin and pull out the unnecessary transmission wires. You may have to do something about the neutral safety as well to the harness. If you’re trying to run the auto transmission with a manual computer though, it’s not going to work well. The manual computer has a lower idle and it won’t be able to control the torque converter lockup and any electrical on the transmission.
Yeah I have a manual transmission, auto harness and computer
Event Coverage
TRS Merch
