Surging at part throttle
Dickinson
ND - USA
Vehicle
Drive
So i recently did my ignition system on my 1988 ranger with the 2.9. I did everything the plug,plug wires,coil, whole new distributor everything. I set the initial timing to 12°btdc and now it surges with the throttle cracked open. It idles a little low and rough. it stops surging once i give it some more throttle. I checked the timing with a light after everything and it was around 15° to 17°. Is my timing too advanced or is it something else.
Did you set the timing with the SPOUT pulled out?
Yeah i did. anytime i tried to set it with it in it would just turn off with makes sense
Yeah....if you try to adjust it with the SPOUT in the ECM tries to adjust it to where it thinks it should be....but it doesnt know where it should be if the initial timing is off.
thanks i'll set it 10 btdc and see if that fixes it.
Yup that worked she runs great now thanks a lot
