The $600 1988 Ranger project. A semi-serious race truck build.
Shackles finally arrived! When the springs are loaded, they are almost flat. That puts the shackle at a backward angle up closer to the frame. I believe this will work in my favor to allow plenty of rear extension.
Isn't straight up frowned upon because of the potential to invert if you ever catch air? (Not likely on this build but...)
I've never heard that. I dont think it would happen because the shackle is not loose on the bolts. IMO; The rubber inside acts like a torsion bar and makes the shackle want to move back into original position when unloaded.
It is for some applications where the spring is going to be completely unloaded. Like off roading or a leaf springed gasser front end.
This truck will never see that sort of a situation and will be droop limited by the shocks anyway. So I don't think it will be a problem.
Good point though.
Good point though.
Looks like I need to research...
Event Coverage
TRS Merch
