Sensor on block above starter?
Ottieotter
Forum Member
California
30"
Hi all, need some help IDing a sensor for replacement.
'87 BII 4WD, 5-speed manual. Sensor is located on the drivers side of the block right above the starter, connector broke off while I was changing the starter out and I cant figure out what that sensor is.
Off the top of my head, the oil level sensor plugs into the side of the oil pan by the starter. Not the oil pressure sensor, but rather the oil level sensor.
Correct, but that would be level with or below the starter. If it is a sensor actually going into the block, and I would think it is being above the starter, it's either going to be the oil pressure sensor or knock sensor. I'm not sure that the 2.9L even had a knock sensor.
The level sensor is on the pan below the starter. I figured out what the sensor above the starter is, it's the knock sensor
It's the knock sensor. The pressure sensor is at the front of the engine.
Glad you figured it out. That's what I was leaning towards, but wasn't sure if the 2.9s had them.
Don't think they are available anymore. If you find that they are let us know, mine has been broken for years.
They arent, and the only one I did find was in Sweden from a company that doesnt ship over here. I'm planning on heading to the junkyard tomorrow, gonna pull a couple out of some other fords and seeing if they're the same thread. Hoping I'll find one that will work
Event Coverage
TRS Merch
