Lower control arm cam bolt
Ocean
NJ - USA
Drive
Hey all, I’m currently in the middle of lowering my 2002 Mazda B2300 with the 3/5 Maxtrac drop. While I’m in there I’m replacing the torn lower ball joints with new lower control arms. The upper arms were replaced sometime before I bought the truck and appear to be in good condition so no need to replace those. I got the drivers side all together with no issues everything came apart with ease. When I got to the passenger side lower control arm I was surprised to see the rearward bolt was an eccentric bolt. I was wondering how I was supposed to remove this bolt? It’s not seized up it turns relatively easy, but when I turn the bolt the washers are getting locked up on the notches in the frame. Do I just cut the bolt out? If I cut the bolt out where do I find a replacement bolt? Both upper control arm bolts have regular bolts. Should I replace the upper bolts with camber bolts, and do I also need to replace the bushings? I’m new to the Ranger/B series platform so any help would be much appreciated! Thank you.
  • Lower control arm cam bolt
the end with 10.9 is the bolt head.
that particular bolt has a Torx end at the other end to aid in adjusting. that's the second pic.
there is a nut on that ( Torx) end.
remove nut, push bolt out.
Thank you I’ll try that. I was messing with it last night after tackling the drivers side. I needed to take a break and think. That makes so much sense now I appreciate it.
Wow, have never noticed an adjuster bolt on the LCA. To the people on the know, is that a 2wd thing, or applicable to later models than my 99 4wd?
Pj got you on the bolt removal.
IMO I'd go ahead and I stall camber adjusters for the upper control arms. There is a high likelihood that the alignment shop will want/need them. Better to go ahead and install yourself while in there, than to pay them or have to do the work twice.
I probably wouldn't worry about replacing bushings unless they were obviously worn (loose, rattling, clunking, etc). I would check over ball joints and tierods for condition and worn/torn boots. Those are big gotchas for alignment shops.
when I did the lower control arms on my 2005 I found an adjuster on the driver side front bolt. elongated hole in the frame.
I'm the original owner so it was definitely factory.
2.3 2wd manual reg cab.
Just did my LCAs and found the same as OP (rear passenger). Best I could find from the interwebs, it's a factory setting. So I just marked mine and put it back best I could. Torquing was not easy.
