2011 4.0 SOHC no crank no start only after the engine has warmed up
sgtsandman
Automotive Technician
TRS 25th Anniversary
Aliquippa
PA - USA
Vehicle
Drive
2.3 EcoBoost
265/70R17
Anything that can go wrong, will go wrong. Plan for it as best you can.
I'm in a bit of a conundrum here being the issue is technically intermittent. When cold, the truck starts and runs fine. But if I drive it or let it idle for a bit and then shut it off, it will crank and pulse like it is trying to start, with an occasional stumble. It will stay that way until whatever is wrong cools down enough and then it will start, run, and drive just fine.
What I've done so far:
Fuel pressure is good static or running. The service manual calls for 60-65 psi and it sits right in the middle on the gauge. The fuel pumps seems to prime just fine, hot or cold engine. The fuse looks and test fine for continuity across the pins. Since the pump primes and will run the engine, I'm assuming the relay and the kill switch behind the passenger kick panel is fine.
The EDIS block tests fine for resistance across the primary pin and all the secondary pins as well as across the the paired sockets for the plug wires.
Since the IAC can cause start problems, I checked power to the valve as well as operation. 12 V to the valve and the valve opens when it has 12 V applied to the solenoid.
What I plan to do:
Check spark at each wire to make sure the wires are good and pull the plugs to make sure there isn't anything odd with them.
Check the crank sensor
Check the fuel injector resistance and use a noid light.
It would help if I had a PC/ED manual but I do not. Hopefully, the CD version of the manual I ordered will have it like the 2019 CD version does. The workshop manuals keep referring to that for troubleshooting, which is annoying since Helm claimed the manual set I got from them was a complete set and never offered any other options. It is not. I had to find and order the wiring diagram book separately, which I did a while ago. And apparently, the PC/ED book is separate as well.
So, aside from the fuel pressure readings… that sounds almost exactly like my green Ranger when the fuel pump started dying. I think the “returnless” system is dumb since what happens is if the pressure drops low enough on a warm engine, it essentially vapor locks. With a return style system, you can prime it a couple times to push the vapors back to the tank and go.
At any rate, do you have the ability to run Forscan? There some tests and stuff it can do that may help locate the problem.
I do have forscan both on my tablet and my windows computer. Since there hasn't been any DTCs, I had not thought to even look at them. I also have an old Actron Scanner that has some live data ability.
Come to think of it, The last time it failed to start on me while I was on the way home from work, I did test fuel pressure by depressing the schrader valve and it did start soon after that. It could be a vapor lock issue.
Yeah, live data and tests can bring up things beyond actual codes. Also some codes don’t set a CEL
Vapor lock is usually one of three things:
Fuel line leak
Fuel pump fail (or the pressure regulator)
Injector leak down
I’m not sure about the 2011, but my 00 has a return off the fuel filter. The regulator is part of the fuel pump assembly. That can potentially bleed pressure off the system. My dad’s 99 and Paul’s 98 both have a completely returnless system, no return anywhere. So your results may vary.
When you have a loss of fuel pressure in the rail, and a warm motor, it can vaporize the fuel in the rail causing the old issue of vapor lock.
Fuel line leak
Injector leak down
The 2011 does have the return off of the filter. I did notice that the pressure did not hold steady with key on, engine off. It dropped down to about 50 psi, if I remember correctly, and stayed.
50 psi should still be enough to keep from vapor locking I’d think…
If it was an old 2.9 truck I’d say the TFI might be dying, lol.
I don’t know if you can get a replacement fuel pressure regulator or not. On my 00 it’s just attached to the fuel pump sender assembly so technically replaceable without replacing the entire assembly but I haven’t looked for one for years.
During my research on who has a Motorcraft fuel pump, I did run across a company that had a rebuild kit. It was aftermarket, so kept looking. I'll order a fuel caddy so I can empty the tank at least most of the way. It's full to the brim right now. Even pulling the bed could be more of a mess than I would like.
EDIT: Rock Auto is the one who has it: https://www.rockauto.com/en/moreinfo.php?pk=11525749&cc=1446675&pt=6256&jsn=661
Carter seems to be a favorite on Rock Auto for a complete assembly.
Always seems like you end up with a full tank either when the vehicle breaks or the fuel pump needs serviced. You may or may not be able to slide the tank back enough to get off the crossmember the front of it sits on. I know my green Ranger is impossible to drop the tank without pulling the crossmember. Moving the bed sucks, but it’s more comfortable than struggling with limited space underneath and the fuel level in the tank becomes largely a non-issue.
Fuel pumps can be a roll of the dice. Want to say I had both a Delphi and a Carter that I had problems with. One was DOA and the other lasted like 2 months. Both from RA. I stopped buying pumps from them after that debacle. I’ve also used a no-name EBay/Amazon special and a couple Spectre pumps.
The 2011 is the same. With the axle in the way, dropping the tank is not an option. Pulling the bed is the only way to get enough room to pull the pump and put a new one in.
I have a 20 gallon fuel caddy on the way to address the full fuel tank as well as a pump to drain the tank into the caddy. There is a pump on the caddy but that is for filling other tanks, not removing fuel from another tank for storage.
I also ordered the carter pump before I saw this since it was marked as a favorite. Cross your fingers that it isn't a P.O.S.
In the mean time, I'll do some more troubleshooting to see if anything else might rear it's head as being a problem and look at some live data while the truck is warming up and after it is in a no start condition. Not much else I can do, other than wait, at this point other than eliminate that nothing else is also a problem.
Sounds like old school coil heating up. I know coil packs were a problem on F150s of that vintage. Wonder if it applies to Rangers too?
Hey Sandman, I may be a little late but I have a good used OEM fuel pump if you want it for parts or to use whole. I swapped it when I was trying to fix my truck but come to find out the fuel pump wasn't my issue.
Here is how I moved the bed back to change my pump without removing the bed entirely.
Hey Sandman, I may be a little late but I have a good used OEM fuel pump if you want it for parts or to use whole. I swapped it when I was trying to fix my fuel pump but come to find out the fuel pump wasn't my issue.
Here is how I moved the bed back to change my pump without removing the bed entirely.View attachment 136575View attachment 136576
I'll PM you. I chose the more sketchy approach of tilting the bed up and propping it with 2X4s so I have more room to work when I was troubleshooting a fuel pump issue in the past. More room to work that way.
Either way, I'm going to need to remove the platform in the bed and the bed cap. The bed cap because there is barely enough room in the garage with everything bolted down. There is no way the bed is going to be moved with the cap on in the garage.
The platform, to access the bed bolts.
The thought had crossed my mind, even though it was testing fine when cold for spark and resistance checks.
The pump decided to completely kick the bucket when I went to get some live data readings. So, that pretty much answers the question. P0232 Fuel Pump Secondary High was the reading while I was in forscan.
