- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
There was one review of someone that just drilled a hole in the case but that defeats the purpose... For the 10 minutes you use the thing the 1/10th of a cfm it leaks through the non sealed threads is not an issue... if I used it every day it would just hang on something instead of being shoved in the case... I don't remember if I was able to fit the inlet screen thing in coolant bottles or not but I think I did since I'm lazy like that and I hate handling coolant... not as bad as brake fluid or gear oil but it's up there...
