Unusual Rust Spot
Broosedamoose
DaMoose is lose!
South East Massachusettes
31 x 10.5
Coming in second just makes you the first loser!
After pulling out the seats and the carpet to do an audio install, I found this spot on the floor behind the drivers seat. There is some surface rust here and there but not like this. Not sure how water is even getting there. The seat bolt isn't rusty so it's not getting in from there. Only the area inside the red line is comprimized. Anyway, should I go ahead and remove as much as I can or just seal it up. The truck is old and I only plan to keep it for another year or so. This is my first rodeo with bodywork so what should I use? I am cleaning up the other spots and then treating them with POR15.
Did you forget the pic?
For just a year or two? Blow out the dust and slop some por15 in there.
Water likely came in through the third brake light seal.
