- Sep 19, 2025
- Age
- 55
- Williamsburg
- State - Country
- VA - USA
- Other
- 2007 Volkawagen MK5 Rabbit 2.5
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- None yet ;-)
- Tire Size
- 265/75/16
- My credo
- Facta Non Verba
2011 4.0 5MT
In the under-hood power distribution block, Fuse 41 is a 10-amp fuse that according to the fuse box diagram is for the "Automatic Transmission"
There is a fuse in it.
Since I have the MANUAL transmission, can I use that as a source of switched (ignition on) power to send as "Supply" to a switch in the cab for a set of additional fog lights?
The "Load" side of the switch will run to a 40-amp relay that will receive power from one of the main Positive lugs coming off the battery.
