Does Ye Olde Vulcan 3.0 have a MAP = Manifold Pressure Sensor?
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Just wondering... recently fixed a huge vacuum leak, now looking for smaller ones... :icon_welder:
I did not check the flex fuel version, but I do not see a MAP sensor on the regular 1999 3.0 engine
Typical rule...
If it has MAF there is no MAP.
Typical rule...
Makes sense... but I think our beloved EEC-IV has input pins for both... at least that's what I remember seeing on a schematic... hmmm...
I guess if I ever need Manifold Pressure readings I could hook up my ChiCom cheapie:
IDK about the 3.0, but the 4.0 did have one with a MAF for 91. It wasn't connected to the manifold though. It was called a barometric pressure sensor. Not sure why somebody thought they needed it. The 92 ECU I have doesn't care...
To warn you of impending rain... or approaching hurricanes? :LOL: Seriously, it sounds like a level of fine-tuning that's just not practical... I mean barometric pressure is dropping, so inject less fuel?... MAF already has that covered!
That's correct...
Some early Mass Air systems did have a BAP sensor. Even some Speed Density systems ( my 86 Bronco II) used both MAP and BAP sensors. They finally figured that out at some point... BAP sensors really aren't needed.
