sgtsandman
Automotive Technician
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Yes, it will bolt right in. The wire harness from your old engine will need to be put on the new to you engine since the plugs for the transmission are different. Both engines will need a detailed inspection to see if anything else needs swapped over.Will a 4.0 SOHC from a 5 speed ranger bolt right up to my automatic transmission? I found the exact same truck as mine on marketplace with a bad frame but motor is good and has fewer miles than mine. I'd be able to swap engines and then fix mine in my own time.
