Core support bushing
Smitty316
Forum Member
Washington, Mo
I've been trying to track down a clunking noise whenever I go over a bump in my 09 Ranger. The control arm bushings are new and my mechanic says that it's not in the suspension. I'm wondering if it could be the core support bushings. I put a jack under the core support and lifted it a little bit and an 1/8" gap does open up between the bushing and the frame. I'd appreciate any thoughts on this issue.
Thanks, Smitty
unlikely but certainly possible.
no way for me to gauge what you call a clunk.
Thanks, I guess a clunk isn't a very good way to describe it. I can just say that there's something loose that bumps together when I go over a bump in the road. I've also wondered about a worn out shock bushing.
shock bushings or spring seats or sway link..
check it all and test it.
When you say core support bushing, are ya talking about the front body mount? I feel a picture might be in order.
Yeah. I was trying to figure out what a core support bushing is and all I came up with is the rubber grommets that the pins on the bottom of the radiator slip into.
It’s a plastic piece under the spring to help prevent squeaking noises.
Why is your RockAuto on foreign currency? Did you move and not tell anyone?
That's just showing the tariff's that the other country is paying.
Yes, I guess that would be the front body mounts. They go under the part of the body that holds the radiator.
Thanks, Smitty
If the front ones are bad, sounds like time to do them all. Polyurethane is actually cheaper. The hardware inside is usually stuck together. Options there are Duff hardware of OEM style from a dealer or LMC. I went the Duff route. Cheaper and easier to take back apart later. It is harder to assemble though with minimal instructions.
Good point Luke, I'm starting to learn towards the noise coming from the front body mounts. It's an 09 so if they're not bad, it probably wont be long before they all are. Do you think that worn out front body mounts would cause the clunking sound that I described? Also, do you know of a good video that shows how to do the body mounts?
Thanks, Smitty
