A/C problem. How do I diagnose?
Saddle Tramp
Likes people who quote bots
⭐Supporting Member
Florida
The A/c went out on my 2011 Sport with the 4.0. The "pully gear does spin freely by hand and will spin when I first turn on the A/C to any option (defrost, recirc, heat...) but it will have no pressure or speeds like normal. It will make a low noise from the pully before stopping. (Not high pitch squealing from the belt.)
I don't know if it's a fuse, computer module thing, switch, or what. Any ideas?
What is "no pressure or speeds like normal"? How and what pressure are you measuring? What speed of what object are you measuring and how are you measuring it? Are you talking about the blower fan under the dash?
No readings from measurements. Just noticing the pulley spinning at first then stopping.
The pressure is from the vents. All of them. It's like a low whisper of a breeze instead of a hair dryer of force. This is in all modes.
On a cooler day, especially if your dash blower is not working, the compressor will cycle on and off. That is how it controls cooling. It has no need to run very much if the temperature is cooler and your dash blower is not blowing lots of hot air over the inside coil.
I think you need to investigate more why your inside blower is not blowing correctly first. You may have other problems but I would start there. Blower motor bad?
I see you have a blower motor speed resistor also, if I picked the correct model.
Thank you.
I got really lucky. It was the Freon. It was so low the clutch disengaged to protect itself. That's why I didn't even get forced air even for the defrost.
Thank you.
That doesn't make sense to me, not sure what the refrigerant charge has to do with the blower fan, but I am glad you got it fixed. If they did not find a leak, this may be a yearly thing for you.
