2.3L ('02-'11) What is this bracket for?
malacarr
Forum Member
Bermuda Run
NC - USA
Vehicle
Drive
nope
nope
factory spec...
I can see where it appears to also hold the A/C compressor, but what is all that other support for. It looks like you could remove it and use some shorter bolts for the A/C compressor. Clearly there is nothing attached to it. I did look at a couple of other engine bays that seem to have something there (added that screenshot as well) but I have no idea as what it is. Is my truck missing something?
That is a resonance chamber to quiet down intake air flow. I get the impression it is not required. Others may know if it is important for some reason.
Your a/c compressor is on the other side of the engine isn't it?
Yeah, that the power steering pump. And definitely plumbed into the intake. The plugs in yours look factory though. So I'm guessing not required. Just cheaper not to deign a smaller bracket for the trucks that didn't have it.,
Yeah, I guess that is the power steering pump. Didn't look at it that closely. But the same would apply if I was to use shorter bolts for it and then the unused bracket could go away I would thing.
It certainly wouldn't be that easy. I'm sure belt alignment goes wonky without some accurate spacers.
If you really wanna get rid of the part of bracket hanging out there,🪚.
Just to follow up, cut the bolts down and wallah... I know being a bit anal, but think of the improved gas mileage with the weight reduction
But I think it will mess your hood up when you shut it while also not offering any weight savings...
Looking at your first picture...
I made an "assumption" that the bracket ducked behind the PS pump and was used for lower support of the pump.
So... there were no bolts that supported the pump to engine block?
No, the bracket sat to the outside of the PS pump. After removing the bolts, I just cut them down and reinstalled them
Funny thing, the bracket was made of bubble wrap so it fits nicely under the hood when closed....
