Proper eye PPE for plasma cutting
97ranger22bronco
Forum Member
Dallas, TX
Does anyone have any suggestions for proper eye PPE when using a plasma cutter?
I only have one good eye so I'm pretty obsessed with keeping it protected. I've seen anything from regular sunglasses to a welding helmet so a real broad range.
I'm using my goggles from my oxyacetylene. They are a #5 shade. All you need is UV protection, and then whatever shade works for you. Any welding helmet has UV integrated.
It's a hot metal burning/cutting operation, so I would thing using the same PPE that is appropriate for oxy-acrtylene cutting should be fine. It might not hurt to Google what the manufacturers of plasma cutters recommend.
I just did a little Googling. Below is a link to a Miller forum. Seems to be a lot of concensus to using a #5 shade with UV protection.
One thing to note is using a welding helmet or a face shield in conjunction with dark glasses will give full fave protection from splatter and sparks. That's something I like.
I have recently gotten a better helmet that has different modes for grinding or oxy-acetylene/plasma cutting. I wear safety glasses with a full face shield for drilling and grinding operations, whether at work or home.
I don't see a link...
Agreed
I started off using oxy goggles but switched to my fancier welding helmet on the "grind" setting which works pretty good
The new electronic helmets are awesome. Clear enough to use just as a face shield, then dark enough to make an arc weld disappear if you turn em all the way up.
