Swaps/FI/Upgrades- best value
b3million
Forum Member
Nowhere
AL - USA
Other
B3000
Drive
Hey all. I've been a lurker here for a few months combing through forum pages trying to find a clear answer to my questions, but everything I have found either pertains to a different engine/trans combination on these trucks, or doesn't give clear information on what the best option is.
So. I've got a base model extended cab Mazda b3000 with electronic 4x4 and an 8.8 rear with 4.10's in it. 5- speed MOD-R1 and a 3.0L v6. As everyone knows, the 3.0 is underpowered and gets mediocre fuel economy on a good day, so I've considered a plethora of options for improving the state of my truck. My end goal is to build a highly capable offroad/towing rig- upgraded springs on the rear end, a 5 in lift, 33's, a locker for the rear axle, and all the other equipment that goes into such a build. All of these additions will make their way onto the truck at some point, regardless of the power option I choose.
I realize the first thing people will say is "Just buy a new truck" but I've got a personal grudge against anything newer than 2010 and anything with a bed shorter than 6 feet. I drove a 2004 5.4 f250 years ago that got 8-10 mpg on a good day, so I don't really relish the idea of getting something bigger. I like the truck I have now and I want to keep it- so I'd like to make it more capable.
Here are the options I have considered for improvements:
1. 4bt swap. I'm partial to all-mechanical diesels and diesels in general. I realize the motor is massive and weighs almost 800 lbs, but given the 5 inch lift, clearance ought not to be an issue. My biggest concern is clearing the 4x4 components in the front and finding a transfer case I could splice to the electronic control already in the truck (or not, doesn't need to be electric) that could also take the transmission-shredding torque of a Cummins. My ideal choice of transmission would be a ZF6 from a 6.0 as ford adapter plates for the 4bt exist and the zf6 would require minimal modification of the truck to bind to existing ford components. The added weight of the 4bt in front would also help eliminate some of the concern of an excessively heavy trailer load, and its torque would make any towing concerns a thing of the past.
2. w100/ W1200AX Twin-screw Supercharger. I'm a big fan of positive displacement superchargers and the torque they provide, as well as the instant power and minimal change to the driving behavior of vehicles. The w100 is a 1.6L 5th-gen whipple, and the w1200AX is a 1.2L 2nd gen whipple which was designed and released with the 3.0 in mind. both of these would provide the benefits of forced induction at a relatively minimal initial cost ($2000-$2695) and one of the two is by default compatible with the motor already in the truck. However, both would require timing changes, fuel system changes, and no small amount of fabrication and time. I'm not scared of fabrication, nor time, but the modifications would require mounting the supercharger somewhere in the engine bay, finding a way to drive it from the crank, rerouting intake plumbing and the throttle body, intercooling the charge air, fuel adjustments, supporting upgrades for the motor, potential electronic modifications, plumbing the charge air pipe from the supercharger output, and possibly more. It would be a fun fabrication project but I'm not sure that a. the 3.0 can take the boost pressure I would like to feed it to make my goal ~300 whp, and b. that the rest of the drive train can eat that either.
3. 302/5.0 windsor swap. This is by far the most reccomended one I've seen. There are four problems with it, however. 1. I want to keep a manual in my truck. 2. I want to retain part-time 4x4 capability. 3. the 302 does not meet my horsepower goals and would require additional modification to reach them. 4. my truck is a 2002 4x4. For some reason, for all my searching, there seems to be no record anywhere of what exactly would be required to pull this off. I know complications come with post-00 rangers, as well as 4x4 rangers, but what those complications are exactly aren't specified. It doesn't seem like a very desirable option, but it's cheap, and for a swap, there's a lot to say for that.
4. GM v8 swap. This one is an idea more than something I want to do. I owned a 3.8L firebird last year, so I've done an excruciating level of research into gm v8 swaps. I know for sure that they are never as cheap as they seem- wiring and mounting alone, as well as ignition control, is a huge expense. not to mention the need for a new gm truck manual (which are excruciatingly rare) as well as associated control modules, and total incompatibility with cab wiring, the need for a new transfer case, etc. make this the least appealing option. This is only mentioned because I know it will be suggested at some point.
Of these options, which seems the best from an economical perspective? What considerations have I forgotten? What complications may arise that I am unaware of? are there other options I have not considered? I'm open to input, and this isn't something I'm going to jump on in the short term- If I'm doing this, I'm doing it right, and I want to take my time with it.
I'm leaning most toward a 4bt swap, or supercharging it. This isn't a race truck, but I want torque and economical long term usability. I'm open to thoughts and opinions. Thanks!
All your engine choices will require modifications to get 300hp at the wheels. The 302 would be the most traveled best parts choices to get there.
The transmission and transfer case will need to handle the extra power from the v8. So use a transmission and transfer case already designed for it from a f150. You will need a small body lift to give yourself clearance for the bellhousing and the HVAC box. If you want to stay at 5 inches of lift, drop the suspension lift down to 3 and put the 2 in the body for clearance for the drivetrain. You would switch back over to ranger/mazda parts at the driveshafts. Find a manual shift transfer case, they used the same units in the f150's through the f350's.
That makes sense. How much torque would you expect a 302 to provide at 300 whp?
Here is 361hp, 334 ftlbs torque.
Here is 240 hp, 325 ftlbs torque
Here is 300 hp, 336 ftlbs torque
Especially later on, f-150 did not use the same tcase as a f350. Width is a huge factor in how well they fit. Getting driveshafts to fit on both the tcase and axles is another hurdle.
97-04 4.2 V6 M5ODR2 is the desirable trans and bw4406 out of same year but any engine trucks is the sought after tcase for the later rangers.
02 and newer rangers are more complicated to swap because of the electronics.
The f150 thru f350 used the same manual transfer cases until at least 1996. When the superduties came out in 1999, I do not know what they used.
Do you know anyone who's built a similar motor with off-the-shelf parts? I'm pretty much sold on the 5.0. I've seen some mustang guys complaining that 300whp n/a is almost impossible on these motors
Your local engine builder... BluePrint is just a company that builds engines. I think they use a lot of their own parts but there are tons of aftermarket 302 parts out there. 300hp is easily achieved with a 302 though. I don't know what the limits of that block are but I would guess probably mid 400's n/a with a stroker kit. Explorer 5.0's are rated at 210 with iron heads, making another 90 with good aluminum heads, cam and some other stuff should be pretty easy.
I'm not sure what else to suggest. I guess I don't feel that "5 inch lift" and "towing" and "highly capable offroad rig" are all easy goals with your truck. My V8 swapped truck has a 6"-ish lift and is very capable offroad but towing with it is not fun at all, and I did a solid axle swap on that. I think if you want the lift, forgo the towing part... if you want to tow, forgo the lift.
Look at the bottom of the article in this link. It has all the parts listed for whatever power level you want.
I get what you're saying. I forgot to mention that I scrapped the idea of a 5 inch lift. I'm squaring up to put bilsteins, keys, and shackles on the truck in a few weeks, which will give it 3" of lift. I don't want or need a sky-rider, just tire clearance. I spend more time in the mud and sand than rocks.
I'll do some more research on aftermarket stuff. heads, cam, etc. I was looking at the B-cam. I also have seen some mustang guys saying the stock explorer heads and intake are pretty good for power, plus something about forged pistons.
My only other question revolves around the manual transmission thing. I know the M5R2 will bind up, but wiring is another story. I read a forum post that said if you use the full explorer rig and run a stick, the CEL will never turn off because it doesn't detect a transmission, and I don't remember if they said you could flash that out of the PCM or not. I thought about jacking a harness and ECU from a 95 mustang with a t5 to avoid that, but I have no clue if that would hook up to an 01 explorer motor. I also remember the t5 has three electrical hookups of its own, and i doubt that the connectors from the m5r2 are the same as the ones on the t5. I really don't want to put a t5 in the truck.
My only issue with it is that all of the builds are carbureted. It's a good resource though, thank you.
I just have a stock HO cam in mine, I have heard there are better cams out there than the Ford Racing/Perfomance/now Racing again letter cams.
A B cam sounds good at idle but dollar per hp there are supposedly better options.
If you don't want to do a carburetor, you could always do a TBI setup... IE, Holley Sniper, FiTech, etc. That will be your easy button for tuning but not for making things play nicely with your existing dash and wiring. I'm not sure how easy it will be to find someone to tune out things like transmission codes that the ECM is throwing... that used to be pretty common but a lot of those vendors got scared off during the Biden regime where the EPA was suing everyone who dared to mess with cars. I know one local place and a guy in Colorado that just simply quit doing any tuning because they didn't want to lose everything.
As far as transmissions go, an M5R2 would be fine IMO. As long as you're not abusing it, you should have no problem with 300hp or so. The ZF 5 speeds are a bit more stout but they are also very large. I think I would rather use either of those over a T5 especially in a 4x4 application... was one of those even made that would easily bolt up to a SBF?
he says 300 wheel horse power
a 302 is garbage for a 300 whp application cammed for truck duty. in 1995 it was the easy option...because it was that or a 350 or 454...then 1997 happened.
you need a stroker, a 351 or a gen 3/4 5.3 or 6.0 gm engine.
for sure the cheap ls days are gone due to age and miles
at this point a gen 2 coyote out of a 150 is best. or a n/a 3.5 or 3.7 V6.
I have a 3in body lift and 5 inch suspension lift and my truck tows pretty good. but it rides on leaf 60s.....so. I am cheating.
today. the cheapest by thousands for me would be a 5.3 swap. I can still get good running 5.3s for decent costs. I would run a 4l80 with the gm case .
just run the gm PCM with a canned tune and put a fork in it.
diesel....no way I would run a 4bt. i would do a gep 6.5 or om 6. again with a 4l80.
Did none of the 97-01 302's come fuel injected? Maybe that's me being dumb, but I was under the impression they were. My whole plan for tuning was mostly pump/injector/valve/airflow upgrades, etc. Crack the ECU and plug-in tuner it until i get what I want. all of that comes after i get the thing in the truck, so ECU and driveline issues are my #1 concern.
That's pretty far down the road, one way or the other. If I get there with my money somewhat intact, a PD supercharger would be my method of really cranking the power up. but that's not really relevant at the moment.
My state's blood-red, but i don't know of any skilled programmers or tuners in my area. Maybe i could ship it to Texas or something.
Thanks for the input on the transmission. I'm eyeballing one that's in a 4x4 f150. I don't know if the m5r2s came built differently for 2wd and 4wd trucks, so I'm not risking it. as for the ZF, I honestly doubt it.
