- Apr 24, 2020
- Kintersville, PA
Cold glav em. Lol.
saving money to buy the parts always seems to to take much longer then putting them on…..
You could put a fancy rattle can paint job on those.![]()
Great progress! But did the shocks really need to have their life cut short?
If you want to have something to aim for... take a look at this thread.... '78 K30 Brushtruck Build - The General Purpose Rig | Pirate 4x4 Definitely a beautiful truck when completed.
Cutting a x or + or whatever you want to call it in the head and using an air hammer makes quick work of the rivets.
At my old job we had a yale with a propane guzzling 4.3The GM iron duke was popular in forklifts but never seen one with a 4.3. Any V engine was rare in forklifts because of the saddle space needed. A V6/V8 would be a massive waste of space. Forklifts favored anything inline... most industrial equipment did... Engines for that kinda stuff dont need horsepower or even torque, they just need to exist while the massive gear ratios do the work. Find an engine that's reliable and it'll do the job... Aka ford 300's, iron dukes, and 2.3's.
The newspaper I worked at had a Hyster with a 4.3 Vortec. It also tipped the scales at like 14k and could lift like 6k worth of paper almost 30’ up. It would also push full stacks of paper around (6 rolls 4’ wide), which happened when things needed re-organized because it was faster to push a stack than un-stack and re-stack.At my old job we had a yale with a propane guzzling 4.3
Torch and a 8-10oz ball peen hammer if you’re good with a torch. Grinder and punch of you’re not. I watched an older guy at a junkyard torch the head off rivets without gouging anything up and just give them a sharp rap with the ball end of a rather small ball peen. I’m not usually that clean with it, I usually have to go back and clean up with the grinder before knocking them out. But the torch does wonders, if you punch it or grind and punch pretty quick after torching the head off, the rivet is still hot and comes out easier.
I think this yale was a vortec too IIRC. It was an 8000lb capacity lift.The newspaper I worked at had a Hyster with a 4.3 Vortec. It also tipped the scales at like 14k and could lift like 6k worth of paper almost 30’ up. It would also push full stacks of paper around (6 rolls 4’ wide), which happened when things needed re-organized because it was faster to push a stack than un-stack and re-stack.
We had a 1993 Taylor TC250S that had a propane fed Ford 460. It kept overheating the old style ignition module so I swapped in a MSD 6al. The stamped valve covers had unstoppable leaks from years of over tightening, so I put a set of aluminum Ford Motorsport valve covers on it.At my old job we had a yale with a propane guzzling 4.3
