You will not get codes if you do not have a computer. Of course if they plug into the vehicle to talk to the computer, they will not get a response. It will not be there. You can pull the computer and all those wires and sensors associated with it, you will be reverting your engine back to late 1970's operation.I do still have to pass emissions and I think with the duraspark conversion you get codes that prevent that, right? I may be moving to a new state soon and would happily make the swap as long as I can register it like that haha. Thank you for everything, I'll try to track down that manual and adjust the carb tonight!
I would be surprised if they plugged into a vehicle this old at the inspection station. It has no check engine light from the factory. But I guess you never know. Your system is known as the EECIV system. And they did use this same system to run the 5.0 mustangs, and all their fuel injected vehicles, till OBDII came out in 1996. After that they still used a updated version of it.
