Power steering conversionWhat is a Saginaw?
It was only used in 78-79 full size trucks with the HD power steering option. Pretty rare. If the Proquipped kit will fit a 2.3, it's the way to go.
Thanks man! Unfortunately I looked up those part numbers and they have been long gone since 2011. I thought Saginaws for the rangers were more common. By any chance do you know of a similar option to upgrade the ps pump to get rid of the whine.Ford Saginaw Power Pump Install
It seems the pumps are available, but not with the bracket or reservoir you need to fit the Ranger.
I did find this:
Ford Ranger Explorer Saginaw Power Steering Pump Conversion Adapter Kit
It says for 3.0 & 4.0. I can't find a good picture of the way the pump mounts on a 2.3 anywhere to compare with.
I found one:
From that I can't see why the EBay part couldn't be made to work? Unless it interferes with the alternator mount... It'd be VERY close.
You'll definitely need to get the wiring, and other things.I have no idea, other than generally, what that is or how you find one and put it together. I’m looking to put AC back into my 87, so every time I see one in the pull apart, I try to get down there and look. Not only do I need all the AC parts, I also need all the brackets and wire harness, etc..
Does that idea work for you? Could you just grab a used system out of an otherwise similar truck?
