bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
any additives to oil for cleaning should be changed within a few heat cycles. especially risoline.
when you knock shit loose you are changing chemistry and can turn the oil to the bearing murdering acidic side pretty quickly depending on the situation. even seafoam.
if you are not actively testing long term, changing regular oil 2500-3k and synthetic at 5 k is pretty standard.
if you have been testing from day one and running bypass filtration you would be shocked how long high end oil can last with proper bypass filtration. a highway vehicle can see 50 k intervals with just filter changes at every 5k with top up....
that costs more then changing it though.
