Brain75
- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
We get a fair number of PATS questions, and in searching I found this:
Up till now I only thought of PATS flavors as 1 and 2, not A/B/C/D/E/F/G, and didn't know the diagnostics of "if it runs for more than 1 second then quits it is not PATS".
Hate to just borrow someone else's content, but websites disappear so quickly it will be gone tomorrow. I think what he has to say should be stickied here or *gasp* made into a tech article... Not asking you to write it Jim
If anyone else wants to throw additional PATS diagnostic / info / fix stuff here in this thread I might even condense it into a nice clean single post thread for an admin to sticky.
If this info exists already I didn't didn't find it in the tech library or a search - please link it here and I'll review it.
The "key article" and some one post responses in various thread was the most info I found with search:
Programming PATS using forscan:
Understanding Ford PATS: The Passive Antitheft System Explained
Ford PATS Passive Antitheft System uses a special key with an transponder in the head of the key. Each key is coded
ricksfreeautorepairadvice.com
Ford Chip Key Basics or What Blank Key Should I Buy - The Ranger Station
This article explains the different Ford chip keys and helps you understand which one you need for your Ford Ranger.
www.therangerstation.com
PATS Programming With Forscan - The Ranger Station
By fastpakr You can now program your own PATS keys without a trip to the dealer even if you don’t have two working keys. Here’s what you need: 1) An ELM327 interface for the OBD2 port. Not one of the … Continued
