Brain75
- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
Ok so lets start this off by saying I am looking for something that is cost effective - something that will pay for itself, not interested in throwing money to the wind.
I have a 1990 2.9L M5OD-R1 2wd that is bone stock as far as engine/trans/axle. Door Tags - Trans: M (M5OD-R1), Axle: 84 (7.5" 3.45 Open), and during paint/rehab I checked both of those and they match.
A F4 axle (3.45 LS) showed up in the junkyard and I thought about grabbing it just to add the limited slip to deal with Colorado roads. Rather than grab it without thinking, I checked a few other things to see if I still wanted a 3.45 or something else would be better.
Obviously my truck was built when 55 mph was the speed limit and no thought to going 75 was on the engineers' minds.
I have read repeatedly that the best economy of a 2.9 will be between 1500 and 2500, so maybe I don't want a 3.45.
I'm definitely going to change tires (switching from 14" to 16"), so we have a lot of variables to play with...
The most cost effective for me to do an axle or gear swap would be to grab a complete axle from the junkyard - the yard wants the same price for gears/center section as they do whole axle, and they want 1/3 what summit/jeggs/yukon wants for bare gears.
So here's my thought, find a 3.27 axle and slightly bigger tires. Problem, no 3.27 was made with factory limited slip in a ranger (the only 3.27 door code is "91" which is 8.8" open).... but the explorer 8.8" did (door code "D1").
So here's my thought, tell me if this is possible or not, dumb idea, or what.
Option A) find a 3.27 LS axle from an explorer (D1) and do the explorer swap (grind off perches and flip them over) - https://www.therangerstation.com/tech_library/Explorer8_8.shtml
Option B) ..... haven't figured this out yet... no way to get a 3.27 or 3.08 in the lighter 7.5" in a limited slip without opening up the wallet to bleed for retail.
Option C) swap the M5OD to a T56 (6 speed double overdrive, final drive ratio 0.5) or similar - probably cost a lot more.
Option D) add a brownie box, gear vendor, etc - anything add on to drop the final ratio - probably cost a lot more.
How common was a D1 axle tag in a 90-94 explorer? (I have drum now, and switching to disc opens up a lot more things which equals cost)
FWIW, I recompiled this chart https://www.therangerstation.com/how-to_pages/gear_ratio_tire_size_chart.shtml
into something more applicable to our gear ratios offered w/o all the chevy and 9" ratios and with the addition of a few stock tire sizes. Also made the whole thing a calculator (interactive with user input) in an excel spreadsheet instead of a static grid (as well as the speed being user input instead of static 65mph, and the final drive ratio a user variable instead of being 1:1.
If someone wants a javascript project I think it would be an ideal add to the tech library.
