I drove my Choptop for years with no gate, you just have to feel for when it clicks into position. Even at one point I didn’t have a shifter at all for it and had to crawl under (not fun). It’s gated now, but that may or may not change in the future because I would kind of like to have a doubler in it and a twin stick t-case, so three shifters plus the trans…If you are ok with not having the gates on the shifter, it can be a simple flat piece with a fork on one end the shift knob on the other and a center pivot.
That I’m not sure of. If you’ve ever grabbed the shift lever sticking out of the T-case and tried to move it by hand, there’s actually a decent bit of resistance there on the 1350 and 1354 cases, so I’m not sure a cable would actually do it, and if it did, you would probably need a pair of cables so you could pull in each directionA thought just occurred to me. How hard would it be to make one of those "universal" cable shifters work?
Edit: Or something sillier(cheaper). Like say a lawn mower throttle assembly...
Lawn mower cable would not be heavy enough. But there are strong enough cable assemblies to do the job.A thought just occurred to me. How hard would it be to make one of those "universal" cable shifters work?
So, shifter boot/bezel is a junkyard thing.I'm in a similar situation swapping a manual 1354 in place of an electric one. I have a complete 1350 manual transfer case and shifter sitting around I can rob the shifter off of but where can I find a shifter boot/bezel? I'm ok with using a universal boot if it comes down to it. Does the floor pan have an access panel I can remove or do I need to cut a hole?
Cabs are similar so maybe? I dunno, never owned any 3rd Gen trucks yet.Does the panel remain unchanged up through the 98+ generation? Easiest solution is likely to just get a tunnel cover from an auto trans truck, cut the holes I need and run two universal shifter boots.
My Choptop I just figured out where the shifter needed to go and cut a hole in my plate next to the manual trans shifter.
