Dana 44 gear pattern acceptable?
Brazil
33"
Hi everyone! I'm trying to get the correct gear pattern on my new set of gears for my Dana 44 rear end, and since it's a PITA, I would like your input about the patterns I'm getting.
Please see files attached.
Is this runnable or I really must add shims to the pinion?
I would be happy with pinion depth. But maybe shim the carrier a tiny bit to get more depth of engagement. How is your backlash?
Backlash is at .0044. Spec says 0.005 minimum. I'm already a little bit too tight in backlash.
I would try adding more to the pinion shim, just to see where it goes. Maybe .008" or so.
I put an 008 pinion shim and reset backlash to 007.
Is this acceptable?
  • Dana 44 gear pattern acceptable?
That's nice and deep and even, I like it
