- Dec 15, 2023
- South Carolina
Does anyone have any experience replacing the timing chain and sprockets on this engine? I've replaced the water pump on this engine in the past and I know it's a job getting to the timing chain but, my first concern is the harmonic balancer bolt on the end of the crank shaft. I've read Ford used Loctite red thread locker on the bolt holding the balancer on the end of the crankshaft. From what I know about red thread locker is you need heat to break the bolt loose. That would be tough if not impossible. Any input would be greatly appreciated. There are some good videos you tube of this procedure but they don't show the mechanic breaking that bolt loose.
