- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
I'm sure that this has been covered before but my search skills seem to be failing me.
I've got a idea popped into my head recently. Something that I don't need, and honestly probably won't happen. Unfortunately once an idea gets in there it's hard to let it go. So here's the situation...
I have an 86 Ranger short bed 2wd that I tore down a decade ago to restomod and V8 swap. Project was abandoned and currently exists as a bare frame and the shell of the cab (with other body panels stashed around). V8 ended up going to the 99, and I've got a complete 85 for the eventual resto. Doesn't mean I just want to scrap it and I've been thinking about what else to do with it.
Among the ideas that's popped into mind recently is building it into an off road toy. I really don't need it, all three of my currently registered trucks are 4wd and there are no offroad parks in driving distance. That said the '70 will eventually be restored and I won't wont to do much wheeling in it at that point. The F-250 will probably be sold once the 70 is restored, won;t have much need for two full size trucks unless something changes. The 99 is only technically a 4wd at this point, it's got an AWD transfer case and is getting lowered like when I can arrange all the right parts. So in the future there could be place for a dedicated hunting and trail rig that is also somewhat street legal.
Staying TTB would be nice, but I don't think that would work out too well using the 2wd frame. My understanding is that not only are the beam pivot brackets different, but that the crossmember differences won't work either. I recall a thread discussing converting a 2wd TIB Ranger frame to 4wd TTB in the past and the subject of changing the pivot brackets being mentioned, but I can't seem to find it since. I do recall I argued against the conversion for reasons, but I don't recall the reasons I gave or what others said.
Thought right now would be to install an EB D44 using James Duff swap components. For the rear, probably the Chevy leafs with a Ranger or Explorer 8.8 (I have a couple) and an adapter for lug patern. 4-link and coil-overs would no doubt be better for articulation, but for what I'm doing I'm not interested in putting in that much to design and build it. Those can come later if I actually used the truck enough in situations where it would benefit. Beyond the suspension, I'd probably run flared fenders in the front, and chop off the frame right behind the rear spring hangers with a simple flat bed built on top.
My questions is about SAS on the 2wd frame. I know that the frames are different between the TIB and TTB Rangers, atleast where the pivot points are concerned. I seem to recall that the engine crossmember is different as well. I'd most likely go the EB D44 route with James Duff parts for installing it, and those should mount to the 2wd frame without issue.
So are there any major issues or concerns with SASing a 2WD TIB frame?
The alternative to using the 2wd frame was to pickup a trashed BII. Use that frame with full width TTB and F-150 axle. Set the standard cab on it, and a custom flat bed to round out the back. Unless I stumbled onto someone practically giving me a BII frame, that's going to be more that I was putting into this idea.
