- Feb 8, 2022
- Saint Paul, MN
I drive a 2003 3.0 Ranger Edge.
I've driven a lot of different pickups over the years and notice they all share the same handling characteristics. They are light in the back and heavier in the front. They pitch downward when we make an emergency stop which in turn puts more pressure on the brakes in front. I've never liked this. I've also never liked having to turn even just a little to avoid a collision. Trucks tip sharply with sharp turns. Granted, most trucks come with sway bars, but they are too soft in my opinion.
I've driven cars that handle really well. They handle emergency moves with little or no problem.
My first emergency stop with the Ranger was typical in all of these ways. I decided to upgrade.
I upgraded to larger Cooper tires roughly 30 inches in diameter with treads slightly more than ten inches wide. Many memnbers here have done the same. I lowered the truck one inch. The Edge comes with a three inch lift, giving me a very modest gain. I installed a 1" sway bar in the front and a pair of leaf spring clamps in the back. I noticed the difference right away. The truck stays level when going around corners...The tire treads stay more or less level to the road. That gives me more traction everywhere and all around.
I also installed slotted cross drilled rotors which gave me greater stopping power.
All that work came into play on my second emergency stop. The truck did not pitch downward when I hit the brakes. Those rotors did their job. I felt my body push forward and even a little upward even. Instinctively I looked into the rearview mirror. The car behind me was not having the same good luck. I looked into the side mirror and noticed I had a small opening so I took it and cut the wheels pretty hard. Still no sway.
I got out of there entirely unscathed. Those in front and those behind me were not so lucky. My truck handled better than the cars. some of you might argue that those rotors might crack some day or wear the pads out faster. Some of you may not light a stiffer sway bar in front. Most of you may not see the need for leaf spring clamps. some of you may have tried one thing or another. But in my case I know that each of these mods worked all together. I'm pleased. I cannot recommend them ehough.
