- Oct 2, 2024
- RI
- 3.0 V6
hello i have a 2003 ford ranger with the great 3.0L and i love my truck but it started Misfiring about 2 weeks back. i was driving it to school and i was on the highway going about 60 65 and as i started to slow down for the exit the truck started violently shacking! then i stopped at a stop sign and the truck almost stalled out it was just trembling and then i knew i had a big problem on my hands so fast forward to when i drove it home by the end of the day it was still rough and shacking like crazy at idle.
so i used my obd2 scanner and it came up with these codes (see picture) but yeah i saw all those codes and was like WHAT 3 different cylinders misfiring and i was like ahh shoot this is going to take a while so i ordered the spark plugs and all ignition stuff but in the meanwhile i tested the injectors and they were clicking away so it wasn't fuel also when it was running and you are standing next to it it smells like fuel. but yeah that all happened and after replacing all ignition stuff i did a compression test on 1 and 2 and 1 was 176 and 2 was 150 then the battery died so i stopped that um pending the rest of the cylinders but i dont think its compression because one of those codes is a too lean code which would mean two much air so i have no idea. oh also i just replaced the MAF sensor today and it did nothing but while the truck was running i swear i could hear a clicking coming from the engine so maby a lifter but that wouldn't explain all 3 cylinders i will investigate that further and do more compression testing.
but anyway thank you for reading all this if you did and sorry for the messiness im not the best at explaining all this and that i basically wrote a book here but anyway i would love to hear some suggestions and solutions. (thank you for your time)
