- May 18, 2020
- Burbank,CA
- 4.0 V6
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
I went to drive the fusion after a long time of not and suddenly pedal was super low. Front pads were fresh, rear worn. I swapped in fresh rear pads (carefully repacking in the piston), and pedal was even lower smh. This is the kind of luck I have been having in general lately. I'm in a mechanics slump.
Anyways did some research and it could be a bad caliper, master cyl, or dreaded ABS module. Caliper check says clamp the lines and if you have pressure, release one at a time until you dont. I was 0 for 4 on that. Checked the master cyl, fluid was low and nasty...I soaked it up, topped off fresh fluid and did a half ass bleed. No dice.
I'm thinking maybe I can get lucky giving it a good thorough bleed as a first shot, but doubt I should be so lucky given current patterns. It does pressure up if I pump the pedal, but dont hold long.
I guess I am asking if its worth even bothering or should I get a new master cyl first and save some brake fluid...and if that dont work, hunt down an ABS module...or tow it to carmax....every bushing and bearing in the front end needs replacement too.
