eightynine4x4
- Oct 15, 2020
- New York
- 2.9 V6
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
Thanks! It actually was pressed in square believe it or not! In the second pic you can see it is seated flush all the way around. Shadows from the lip make it difficult to see, but if you were peer into the lip, the edge of the joint is sitting flush inside the full circle around.If you can find a socket or a short length of pipe that fits over the top part of the joint and sits on the ledge, you should be able to press it out and reuse it. It doesn't look like the joint was pressed in straight and square, that may be why you can't get the clip on. If you do need to grind a little materiall off the steering knuckle it shouldn't hurt anything but try repositioning the joint first.
This knuckle was manufactured not flat at that surface, big time. That angle you see in relation to the ball joint is literally the bend of the shape of the knuckle. I’ll need to grind away i suppose.
I’ll try to rig up a pipe to work as the receiving “cup” for the large stud side of the joint to go into.
