- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Not on a swap, more just questions about my boat engine since it stuck a valve or two...
It's an '83 351 windsor that's been rebuilt at some point, it used to be the hipo 290hp version but if I've heard right there would be 3 lines on the cylinder heads if it was, which there aren't anymore. I've also heard those needed premium which I'm glad to not need... Anywho I just pulled the one head with issues so far and saw a D8 casting number somewhere. The pistons have a dish in the middle so I'm assuming lowish compression.
Main question I have is what stuck the valve? There was minimal rust on just the cylinder head around that valve, the only thing I can think of is that valve happened to be closed and there was some water sitting over it over the winter and rusted that particular valve guide? Odd part is the cylinder in question is #2, odd... It has modern Felpro valve stem seals with springs on the lips.
Since I can't leave well enough alone I was planning on pulling both heads and all the valves making sure they are all in good shape and do some die grinder work in the ports... can't hurt to be a better air pump... The tack doesn't work and it meets all my needs except fuel consumption (need to do some jetting once it's back together anyway) but more power never hurts
I'll dig back into it Thursday night and update when I get the valves out, maybe even have pics...
