- Aug 27, 2018
- Orange County, NY
- My credo
- Don't wait till it's broken to fix things
Hello, I was looking for some information or advice on what's compatible between the Explorer and ranger. So here's the situation: I have a 1993 4 L 4X4 ranger. I need to basically replace all my brake Parts in the rear. I'm talking wheel cylinders, backing plates and some of the brake lines on the axle. It's all pretty rusty. I live in New York state.
So I thought about just putting in a whole new axle out of an explorer, maybe I get a locking differential out of it as well or possibly a disc brake set up too. Welding the spring perches on top is not a big deal for me. Somebody on here suggested that I stick with drum brakes because I plan on doing a lot of Towing once I get a enclosed trailer for all my tools, but I'm not sure if it matters. I'm told there's better stopping power with drum brakes then discs because of the increased surface area of shoes compared to pads. Anyway I came across somebody selling an 8.8 axle out of a 2010 Ranger with disc brakes and 410 gears. My Rangers got 3.73. At first I thought I could just swap out the gears but then I came across an ad for somebody selling for really cheap, like 10 bucks the front differential out of a 99 Explorer with 4.10 gears. They say the carrier may not be good but the gears are still good. I believe I can swap out the front gears but I just want to double check here if anybody knew if there's going to be a problem between the front end gear out of 99 Explorer into the front end of a 93 ranger. I'm only thinking about this because I'm told the 410 would give my truck a little bit more towing capacity especially when I get myself a little travel trailer.
