Curious Hound
I know a guy with a website
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
As the title states; m5OD-R1 manual transmission with 4x4 tail housing and 1350 manual transfer case. I am told that this will fit 2.3l 4 cylinder engines as dictated by starter mount on passenger side. I've done about an 85% external cleaning on it. Have NOT checked, drained or refilled fluids. The transmission shifter needs a shifter rebuild kit. The 2 pins that prevent the shifter from rotating are missing. I have included a picture of the Dorman kit that contains these parts. I temporarily installed the pins from a kit I have on the shelf so I could verify operation. It shifts through all forward and reverse gears and feels smooth when I rotate the input shaft by hand in each gear combination. Same for transfer case. Shifter knobs are effectively missing. Also have front drive shaft to go with it
I picked this up off FB marketplace because I feel sure that somebody on TRS will eventually want this as a replacement or to swap from electric t-case to manual.
$350.00 plus shipping or my fuel expenses to meet you somewhere reasonable for all of it. Located in Wellford, SC, that is northwest South Carolina just off of I-26 and I-85. Also close to I-77.
This us the rebuild kit you will need
