Uncle Gump
Boomers gotta Boom
⭐Supporting Member
TRS 25th Anniversary
- Sep 17, 2018
- Ottawa
- State - Country
- IL - USA
- Other
- 1986 Bronco II
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 1 inch
- Tire Size
- 265/75/16
- My credo
- Lead or follow... or just get out of my way
Does your timing light have advance? Maybe it went wonky on you?
Have you tried a second timing light? Two timing lights wouldn't be wrong.
If a distributor was off a tooth... chances are there wouldn't be enough adjustment on the distributor to get it to run. They typically pop and bang when off.
Did this truck and engine drive normal before this timing issue? If so... cam timing is... or was correct...
