Anyone install 1.8:1 Roller Rockers in the 3.0 Vulcan?
Lefty
Saint Paul, MN
I 've got a bad case of cabin fever. I confess. My latest thought is to install roller rockers on the top of the engine. That's all. Maybe nothing else. Have any of you tried this? What can I expect? A little more HP and maybe MPG too? And if so, would a 60mm throttle body help?
I've always thought that I would get a different engine someday, one with a little more performance. Of late I have changed my mind. My Vulcan still runs pretty tight after 150,000. It's responded well to simple external changes, maintenance, etc. It will continue to work well for a very long time.
Besides, the Vulcan is a good choice for a little truck. It doesn't weigh as much as the 4.0 or the 5.0. It handles good.
On paper it should increase the performance because it reduces the rotational friction.
How much so? I have no clue and a dyno session would need to be done to find out.
Does your motor have the the overhead cam? I looked in the tech section but it only covers the the cam in the 3.0L to 2001.
There is a lot of geometry that goes into roller rockers, way more than I'm willing to take on anymore just to get the right ones that will stay on the valves center line.
have a watch of these 3 video's from Steve Morris Engines about rockers to learn a bunch and I mean a bunch. These links go in order:
Also check out his Youtube channel and go to playlists for his channel and click on Steve Tech. This is one very smart engine builder but mainly focuses on boosted engines.
All the Ranger 3.0's are the pushrod Vulcan version.
The reduction in friction is less of a benefit than the change in ratio. The 3.0 has a 1.6 ratio in stock form. Switching to a 1.8 ratio increases valve lift similar to a change in camshaft profile.
I put Morana's 1.8 rockers in my 3.0. But I did it as part of a full, supercharged engine build/manual trans swap so I can't say what, if any, impact they had individually.
I'm pretty certain they're LS based rocker arms with custom machined pedestals. They were Harland Sharp pieces, which was reassuring compared to some no-name stuff from wherever.
I also opted for Morana's upgraded valve springs at the same time. Stock 3.0 valve springs have been known to float valves on stock 3.0s, so I thought it was logical to upgrade to something a bit firmer with the increased lift and speeds involved.
There have been people in the past that used lightly modified Ford 5.0 roller rockers in the Vulcan. I've read some claim that the geometry of those rockers does not allow the roller to stay properly centered on the valve tip at all times. Just something to be aware of if that's what you're considering.
Because I installed my rockers with my engine on a stand, I was able to closely watch the valve tip as I cycled the engine by hand and I didn't see an issue with Morana's rocker geometry. YMMV
In this case more fuel would need to be added to the cylinder also. Would a stock ECU's fuel trims be enough to compensate? My guess would be it wouldn't and a aftermarket ECU would be needed to adjust for the extra fuel needed. I'd like to hear your thoughts on this.
All else being equal.. going to roller rockers on SBC's is usually a guaranteed 10hp.. pretty pricey 10hp.. but 10hp none the less
it should sound cool if you do roller rockers and solid lifter. i had a 302 from a hertz weekend racer in my 65 mustang and it had solid lifters and roller rockers. everyone always thought i had a diesel engine but it would lift one front tire from stop if you dropped the clutch and launched like you were racing
I'd bet that it would run without software changes, especially if the truck were flex fuel and had larger injectors and broader spark/fuel tables to begin with. I'd probably be careful at higher speed/load conditions where it might run lean though.
Of course updating software would optimize the situation and allow for maximum gain and better driveability. You don't have to completely replace the ECU though. You just upload a new tune with the necessary changes through the OBD port.
Tom Morana Racing says that there is some gain in valve lift, meaning the engine would breathe better. I would imagine mileage would suffer while performance would be gained.
I would imagine that the 60mm throttle body swap (discussed in the tech section) would also be useful.
Application: 3.0L Rangers, Mazda, Tempo, Taurus, Sable, Windstar, Aerostar.
This bolt-on is favored by many, as an alternative to a camshaft, as you get .060" more lift at the valve, avoiding the expense and time of swapping your camshaft. Also, there are no issues fitting under your stock hood!
1.7:1 also available for those who intend on going with an upgraded cam. (heavier springs will also be needed if upgrading your cam).
*Please note-if you have an upgraded cam, it's suggested that you go with an adjustable valve train (as longer pushrods are not available).
Up to 18+hp. gains.
$475. USD.
Maybe also more performance with a junkyard 60mm throttle body.
Yes, okay, but hopefully this is a project that might work without rebuilding the entire engine.
agreed
Thank you. Those videos will help. This is just a stock 3,0 Vulcan. My hope is that this mod alone will mildly enhance performance and do so with rebuilding the rest of the engine.
You are very welcome. These videos cover different types and different manufactures so a fair bit of knowledge can be learned from them.
I believe in the last video he covers the tip of the valve with coloring and runs the rocker over it so you can see where the rocker rides on the valve stem. It's a good way to know your alignment is good. Keep in mind when he talks about pulling rocker studs out of the head that he is referring to a high horse power / high torque engine. Although the rocker stud deflection is a real thing even in the 3.slow motors.
If you do this mod you will for sure need a tune for the ECU so start looking around you to see if someone semi local can do it for you.
