So far I haven’t had much luck with welding a nut on. I have been able to weld something on or blob it up enough to grab with vice grips or a small pipe wrenchI've seen a bolt welded onto a broken one with a torch and brought it right out of there. Of course giving due time for necessary steps to cool prior to proceeding
No sir, This was a bolt, with a un-distorted head, held in place with a channel-lock pliers and torch heat-welded onto the stuck one(I believe he got it white hot where it joined prior to letting it cool to a level water could be added to the equation), while we were sitting there eating lunch at a job I was on. Before we got done with lunch it was fixedSo far I haven’t had much luck with welding a nut on. I have been able to weld something on or blob it up enough to grab with vice grips or a small pipe wrench
I think it’s already rounded. He’s going to need something to grab it that the breaker bar can attach to.I'd get something like what TW205 recommended, then heat the flange where the bolt threads in to loosen the locktite and turn the bolt out with a breaker bar of impact wrench. I don't think the hammer and chisel method will work good on a locktited bolt.
That's where the tool TW205 recommended comes in- it's like an extenal version of an easy out.I think it’s already rounded. He’s going to need something to grab it that the breaker bar can attach to.
If one of those will fit and grab, it’s a good option to try. There just isn’t much room for any bulky tool where that bolt head is. I’ve had trouble trying to get a 3/8”drive socket on those bolts.That's where the tool TW205 recommended comes in- it's like an extenal version of an easy out.
My bathroom scale seems to argue that point.Unfortunately, the older you get, the less "ass" that you have.
