300 i6 sputtering and barely idling
That_4.0_ranger
Forum Member
Appleton,W.A.
4 inch
33X12.50-15
Recently my 1990 f250 with 300 i6 and 5 speed is sputtering really bad when driving and it gets worse the more electrical I turn on in the truck I replaced battery and alternator as well as battery cables and it’s still doing it dose anyone else have any other ideas?
I second that ^ … my 89 bronco plow rig has the inline 6 and it’s doing the same thing… new, cap and rotor, battery, 3G alternator conversion, plugs and wires, fuel filter, air filter… yet it misfires and sputters and gets worse when I use the heater, or anything electric… still runs and drives and pushes snow! Gotta give it to these old trucks!
What kind of carberater you got? Mine used to get a couple loose screws on it sometimes and all it needed was cranked back down
90 is EFI.
Hows the various ground straps look?
Need to get a voltmeter and find out what your system voltage is while running. Sounds like a weak alternator or loose/dirty connection somewhere. The more electrical stuff you turn one, the lower the voltage goes. Low voltage could be affecting fuel pump and pressure or spark.
I have recently replaced all the same things and it still runs and drives but when it comes to hills it lacking in any amount of power but I thought it could be fuel but then when I realized that the more electrical I turn on the worse it gets so I’m am just stumped
I
checked the voltage and it’s charging at 13.2 at idle and when I turn all the common electrical stuff (heater,lights,radio etc) it will sometimes go all the way down to 12.5 but also whe. I unhook the battery completely it runs the exact same with all that on so I replaced the battery yet again and still nothing
Your not charging correctly.
Does it have an external regulator?
I
13.2 is getting a bit low. Should be closer to 14.
Yeah that’s what I thought because every other rig I’ve had charged anywhere between 13.6 and 13.7 my old red ranger even charged at 14.1 (yes I know that probably to much but it never caused a problem so I didn’t touch it lol)
