- Nov 20, 2018
- MKE, WI
- 2.3 (4 Cylinder)
- Total Lift
- stock
- Total Drop
- stock
- Tire Size
- stock
2011 Ranger XLT 2wd supercab here with just over 120k. About midway through last summer, I bought a set of Hankook H735 tires from Discount in the stock 225/70r15. I've always been a Michelin LTX guy when it comes to pickup tires, but they're no longer offered in the stock 2WD Ranger size, so after seeing mostly glowing reviews, I figured I'd try the Hankooks. They have a 70k treadife warranty, so I figured they'd at least be comparable to the Michelins in longevity. I ran them for the rest of the summer until I mounted winter tires on a different set of rims, marked each tire, and rotated them when I put them on this spring. After one full summer of use, I'm noticing that the front tires are starting to show some noticeable feathering on the outer edge. I've had the truck into two shops for an alignment, and both times was told the alignment was within factory specs. I know outer edge wear can be a symptom of under inflation, but I typically run my tires a bit higher than the 30psi on the placard - usually 35 all around if the truck is unloaded, 35f/38r if I have the heavy fiberglass cap on or other stuff in the back. The rear tires are showing no noticeable wear whatsoever. Has anyone else experienced this issue with these tires? I think my next stop is to find a dedicated alignment shop, but part of me still feels like even if the alignment isn't "perfect" but is within factory tolerances and tire pressure is even higher then factory, I shouldn't be getting outer edge wear like this.
