- Jan 23, 2011
- Bronson Michigan
- 2.8 V6
- Total Lift
- 6” skyjacker 2” body
- Tire Size
- 33x12.5
About 100 lbs.wonder what the weight difference is between a 2.8 and a 5.0
Those are 31x10.50-15 tires. I think it could use something a little more street friendly and smaller, but those are what I have currently. As it sits, the torsion bar adjusters are backed all the way out which makes it sit level roughly speaking. The rear is an Explorer 8.8 done as spring under axle. So definitely lower than stock (my fat arse doesn’t really fit under it anymore). I haven’t calculated how low yet.Looks great! Good luck!
What size tires? And is it lower than original, lowered from stock?
And just my two cents, but even a good rustoleum custom paint job won’t quite get it on that front bumper. Got to do a little bit better on that when you catch your breath.
Again, looks good, good luck!
Somehow that and the loud exhaust seem to make people more prone to pulling out in front of me to putt along though..It certainly does look mean with that dozer blade up front.
Somehow that and the loud exhaust seem to make people more prone to pulling out in front of me to putt along though..![]()
New Bosch wipers for the Mazda, inspection tomorrow. $35. They work great, but what ever happened to the days when you could just get the rubber blades and replace them into the arms?
That's not bad. Wow. That's actually nothing reallyAbout 100 lbs.
