lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Theoretically grounds should be good if some lights work. Definitely a good call on checking at connectorsNext place I would check is the connector right there in the corner of the frame rail and crossmember. Unplug it and check your power there. Could also check the ground on the crossmember.
