The shed rebuild continues. I used The Missing Linc to go get six bundles of shingles to cover the additions. I got half of them put on. I’m way too old for that crap.
I mix my projects when I need similar tools and materials. If you remember, I just fixed the back steps. The bottom post and handrail on the stairs was always wobbly, so the new one is sunk into the ground, seems sturdy as a rock. But that wasn’t good enough for me, so when I brought the shingles back, I tried to knock it over with the driver-side rear view mirror. Turns out I did a pretty good job on the post.
As I was building The Missing Linc, both mirrors were worn out at the ball swivel. I set them in place with some five minute epoxy, because otherwise, they looked pretty good. So this time, I used JB Weld. The tubes that were in my shed of miracles were so old, I had to get at it by cutting the bottom of the tubes off with tin snips, and squeezed it out with pliers. It still worked like a champ. I bet you I’ve had that JB Weld for 25 years.
I’m going to stay away from the post from now on now that it’s tested.
