- May 11, 2023
- Dudley, NC
- 2.3 (4 Cylinder)
I have a 3007 Ranger with the solid glass rear window. Would a 1993 sliding window fit my truck? Thanks.
Searching our forums, I found this;
up to 1997 the single cabs had a gasket set rear window and at that different size. The extended cabs 93-97 had a bolt in with tar gasket rear window. 1998 and up single cab as well as extended cab all have the bolt in with tar gasket rear window.
Bolt in window swaps with bolt in window single cab to extended cab. Ive used a 1993 extended bolt in window in a 1998 single cab with the bolt in window. Ive used the solid rear bolt in I removed from the 1998 and its been in a 1995 extended cab and a 1997. Ive pulled a 2001 single cab bolt in window and fit it to a 1997 extended cab.
You pretty much cant use the single cab rear windows from anything 1997 and older. Those are gasket fit only. The windows are already gobbed with the tar gasket sealer and you most likely will not have to buy or use anything extra if you pull one from another Ranger. All the tar will come off with the window. Its honestly a 15-20 minute job you can do yourself.
I have a 93 extra cab....so its a bolt in?Searching our forums, I found this;
Anything special I should know about popping off the trim?That’s how I understand it.
