- Feb 8, 2022
- Saint Paul, MN
A CAR burated CAR has a C an A and an R"ar no c"...
Does not compute...
A COMPUTER Car is just a COM
Does not compute...
My sentiments exactly. Maybe the members know whether or not better gas pays for itself.I'm trying the upgrade your fuel for a bit.
Filled up payday and it seemed to be floating on air, maybe cause my wallet was so much lighter.
Coming home a few hours ago I topped it off and drove the last 20 miles or so thinking the engine was doing a whole lot better.
It had better be because that's up 15%, at a time when that makes a difference, but I'm not complaining, thinking it's doing well
My sentiments exactly. Maybe the members know. Does better gas pay for itself?
You have made a very good point. I should say that after filling a nearly empty tank, I noticed some improvement right away, but after driving 30 miles, I noticed even more.The best answer I can give you is maybe. It depends on what you are using the truck for at the time and what your fuel consumption was before using a higher grade fuel and after.
It also isn’t an one tank and done. The fuel system has to go through a few refueling cycles in order for the computer to learn and adjust.
So, the better fuel CAN give better mileage and zero out as far as cost but it isn’t necessarily true.
One place where it more than likely make a difference is when you are hauling a load or towing. The engine system won’t be retarding the timing and fuel as much, or at all and will give better power, this better fuel economy.
This is a recommendation by Ford for the 2019+ Ranger when hauling or towing. Depending on the engine in the older Rangers, it could apply. I can see it as a thing with the 4.0 SOHC since it has such a high cylinder compression.
I'm afraid you're right. AND much as I like fancy gas, I'm tempted to drive with a lead foot.Fancy gas doesn't pay for itself in my location unfortunately.. 93 is usually .75 cents to a buck more a gallon at most places compared to 87.
I miss the days where it was only a dime difference between grades![]()
Maybe they had been filled with higher octaneIn the hollywood movies, cars can sit covered up for decades... and fire then right up for a chase scene.
@CrabGuy is making a very good observation here. Those Ford engines seem to be especially more responsive to good gas.Mine is definitely running smoother and stronger. At Love's there's 87, 89, and 93. I'm doing the 89 and it's still 40 cents a gallon more. I keep continuous records of mileage so it won't take me long to begin knowing the definite results
