- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
How much lift do you have, what size wheels and what size tires? That’s exactly the Missing Linc’s body, and I want to add some Lincoln 15x7 turbine wheels and tires, but I don’t want to do the work if it’s going to rub. They’re also 5x5, so they’ll also sit out another inch with an adapter. I’m concerned about it rubbing when I turn. Probably will be something like 235/75/15s. Mine is a 2 1/2 inch lift.
Pretty sure it's somewhere around 6" lift, got the parts used... the wheels are 15"x8" and tires are 35x12.50, I did have to trim the back of the front fenders and the front and back of the rear fenders a little but I rolled the edges of both so it doesn't look like I did anything... with 2" lift and 235's you should be fine even with some extra offset on the wheels I would think...
