lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
I know, wrong forum, but I really kinda need some answers within a few minutes if at all possible, after that it can be moved to the correct forum....
Anyway, I'm going to look at an older Craftsman lawn tractor here in a bit and the guy who has it says it will not start... claims that he replaced the starter switch but that power is not making it past the relay now. I'm assuming that it is possible that the starter switch was wired incorrectly and is the reason for no start.
He claims there is power to the relay for the starter, so my thought is to try taking a jumper lead from the battery and touch it to where the ignition switch gives power to the relay to see if indeed it is the switch that's not working right.... except I'm not sure if I need to tap my jumper off of the positive or negative side of the battery to do this....
If the relay itself proves bad (as in my lil jumper idea doesn't work), can anyone explain the trick for jumping the terminals of the relay to start the vehicle with a screwdriver?
It's a 12 hp, 6-speed tractor, btw.
I was also told that the starter seems to be malfunctioning.... anyone happen to know what it would cost to fix that while I already have your attention? Or where I could get parts to rebuild it?
